Hi All,
I'm not an electrician but trying to research the following issue for our lighting needs :
I am replacing GU10 halogen lights with LED spotlight but have found the following problem :
I don't want to save electricity I want a much brighter living room/kitchen.
In theory since all the sockets rated 40watts I think I could get a 40 watt LED bulb that would be multiples brighter but so far the best I've found is only 9 watts and 850 lumens.
So the questions is if there's any brighter GU10 bulb out there? In theory a 27 watts LED could be around 2550 Lumen but I can't find anything online.
Floorstanding lights have this amazing 4000 lumen bulb, 3 of those would be great for our space but they look terrible/don't fit the style of the rooms and of course I couldn't put any of those in the middle of the kitchen.
Any comments, suggestions or ideas are welcome.
Thanks,
Viktor
I have GU10 sockets installed so that's pretty much it - I was wondering if brighter LEDs exist at all? Everybody seems to want to sawe power by searching for the equivalent of say a 50w halogen bulb, i want to go the other way - I'm looking for a usper bright LED that has a similar consumption to regular bulbs.
Am I making sense ?
I have 6x7w Led in place of 6x50w halogens preciously. They are far far brighter than what I had originally. Even during daytime they brighten the place.
Not sure the lumen output on them, but I think the 5W Bell gu10 I use for jobs are pretty bright @350 lumens. So those 850 lumen ones are gonna be extremely bright I’d imagine.
I'd be looking for 3 x 4000 lumens but those would be floor standing floodlights and they would look ridiculous in our living room but I can't place 15 LEDs as I have only 6 sockets so i'm looking for the brightest LED possible, around 2000 would be nice.
I've used 350 lumen lights before and they are extremely dark, you probably can't read a book properly by that output.
No I'm not joking - I have only 6 GU10 sockets in a large kitchen-living room space - it's very long and room, about 13 meters that is about 4.5 - 5 meters wide in one and and narrows down to zero with a curved wall on the outer side.
In this space the 6 x GU10 halogens worth about zero so i'm replacing them normal LEDs but they're still pretty dim to my taste.
I have seen 4000 lumen lights in John Lewis, the kind the lights your ceiling and provides a nice flood in the room but because of the shape I'd need 3 of those = 12,000 Lumens total but they're ugly and as I wrote before I can't put one in the middle of the kitchen so I'm looking for some kick---- super bright LEDs, so far the best I've found is 850 lumens.
I'm simply wondering if there's any better/brighter or if there's any other solution that solves my problem ?
I don't think you will get much more out of a GU10 configeration.
The main limitation is heat dissipation.
The bigger the LED light the more heat it has to dissipate.
Thus the shell is bigger to dissipate more heat.
I have seen 3000 lumen Led bulbs
But their big, about the size of an 300w incandesant bulb.
Wait until you get the 9watt and test that - as has been said, for the size of a GU10 9 Watts 850 lumen is bright.
As Murdoch said change the ‘k’ colour from 2700k halogen(warm white) to cool white 4000k as this may suit you better. 6000k colour is a blueish daylight and doesn’t suit a lot of places.
Wait to test the 9watt
To put it simply you don't have enough downlights.
Rule of thumb, 800mm off the walls and no more than 1.4 meters apart.
You have 2 options:
1. Add more downlights
2. Use plugged in lights too
The other thing to consider is beam angle, e.g. a 60' beam angle will provide more light directly below it, than a 120' one of the same lumen output. The 120' one would provide more overall light, but might not be bright enough for you, sat underneath to read a book for example.
You could consider having some of these installed, to replace your existing down lights. The manufacturer may be able to advice you, on the lighting style you are trying to achieve?
FGLED10 – The High Output Fire-Rated LED Downlight | JCC Lighting - http://www.jcc.co.uk/fgled10/
Edit, as Murdoch says, your existing layout may restrict your desired lighting levels
As others have said, there are nowhere near enough downlights for that space. Any GU10 you fit will still be disappointing with your requirements and expectations for an ultra bright room.
You should add more downlights or change the lighting layout completely.
you could fit 20watt downlighters, but you'd need larger holes. approx 5" diameter.
Yes, I'm renting it, otherwise I'd have a completely different lighting, I'm not keen about spotlights at all.
Then surface mounted LED panels might do the job (as Vortigern says), and fairly easy to re-instate the original lights if required, with minimal re-decoration. But get an electrician in to do the job properly. Maybe talk to your landlord about the problem.
Just to second getting some wider beam LEDs. I've got 4x 110 degree 400lm GU10s that illuminate my living room, which is about 5m x 4m. Brighter lights aren't worth anything if they're only pointing at a 1m spot on the floor
I think the problem with cutting larger holes is the Landlord may charge megabucks to re-instate the original lighting (bang goes your deposit). At least with surface mounted LED panels as @HandySparks has observed they are easy to remove/re-instate. You could leave the spots as is and just have the panels switch on.
London
Brightest GU10 LED - or maybe something else ?
Viktor,
Richard Burns,
