skamuk
I've told him to get a sparks in to do it I obviously haven't got the knowledge or experience in this area. I'll meet you lot in the pub as well I think! Thanks everyone
MFT wont do Zs, can do Ze and (r1+r2)/4... Seems like a long way round for me. I was planning to disconnect all cpcs on the circuit, untwist them all, then put wander lead on cpc leg 1 and test continuity at each socket, until I find the first socket in the ring, then do the same with the second cpc on leg 2 until I find the last socket in the ring. Once I've confirmed continuity between CU and first and last sockets I will move on to test cpc between each socket. Would this be the logical way to do it or a long way to do it?! - Also, would this not be the reason the RCD is tripping? Or will I need to locate a N-E / L-E fault somewhere as well? Thanks for your help everyone!
Zs = Ze + (R1+R2) / 4 - So if I did this equation for each socket, the one (or more) with the high readings will be the culprit(s)? Is that what your saying?
FFS, no it isn't.
Page 101 OSG states: The earth fault loop impedance (Zs) is required to be determined for the furthest point of each circuit. It may be determined by: direct measurement of Zs, or direct measurement of Ze at the origin and adding (R1 + R2) measured during the continuity tests (10.3.1 and 10.3.2) (Zs = Ze + (R1 + R2). If you look at 10.3.2 page 94 it states: The readings obtained at each of the socket-outlets wired into the ring will be approximately one-quarter of the resistance of the line plus cpc loop resistances, i.e. (r1 + r2)/4.
OK, the CPC being split is highly unlikely to be the cause of your RCD fault, however, here is a very quick way of finding your earth fault.
Get a socket tester (3 neon variety)
Unplug everything from the ring main
Disconnect 1 leg of the CPC at the CU
Go around each socket in turn with the tester, at some point you will go from a fully serviceable ring to a 'no earth' indication. Or vice versa.
Stop and investigate further
Simples......
Really? I didn't realise there was a difference between r1 r2 and R1 R2. My bad! What does the capital letter version stand for?
