Discuss BT master socket in the UK Electrical Forum area at ElectriciansForums.net
J
jenions
Just a quick question, is it ok to change the Bt master socket to a decorative phone socket? Or do I need to keep the horrible white one?
Ah ok I was looking at the modular plates where u can make them up and shifting the line to that, think il just stick the standard one there then
The master socket has a couple of extra components in it and every house needs to have one master socket then the additional sockets can all be slaves. You could install a master socket anywhere even if it's not going to be used so you could put the master under the stairs or in a cupboard somewhere, it doesn't even need a phone plugged into it. Once there's a master, all the other phone sockets that are visible can then be the modular plate slave sockets.
Reply to BT master socket in the UK Electrical Forum area at ElectriciansForums.net
htps://we.tl/t-JHXw09romZ quick share to photo Hi there. I am trying to convert previous cable network cat5e installed when had non fibre in 2015...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Hi Guys Just first fixing fixing a new build and master BT point needs to be in the basement plant room/ next to rack. BT incomer is overhead...
Hi, I would like to add a new socket in the bedroom. Current room configuration: 3 existing sockets - wiring coming from the bottom (under the...
Electrical2Go - A Guide to Click Sockets: Which Is Right For You? Click Sockets Guide: Which is right for you? Click is a leading manufacturer...
