Discuss Burned plug socket when i plug in the vacuum cleaner in the UK Electrical Forum area at ElectriciansForums.net
zofopage
Hi ..right where do i start ..ill do the best i can !! i have an extension lead and in it are plugged a fridge , a separate small freezer , permanently ..and i use a small table lamp in the same extension also a vacuum cleaner ..have done this for many years no problems ....however last night something went POP !! [like the sound of a plastic pop bottle when you squeeze it and it pops out again] and i could smell something burning ..the socket that the hoover was plugged into on the extension was black ...well i thought it was possibly the extension lead as it was quite old , so today i brought a new one £15 ...only for the exact same thing to happen again POP !! and black around the hoover plug .....i then plugged in the hoover 'DIRECTLY ' [no extension lead this time ]into another wall socket at the other side of the room ..again POP!! now a black wall socket and burning smell ..ps i cannot open the plug on the vacuum as its a moulded one ..
The plug is damaged and needs to be replaced. Any socket that it has been used with also needs to be replaced, otherwise the problem will spread around your house like an infectious disease, with other plugs that have been used with a faulty socket also becoming damaged, and then affecting any other sockets that it is plugged into.
It's impossible to say whether the extension lead socket or the cleaner plug was the first to fail, but in general, the sockets on an extension lead are of a lesser quality than those fixed to a wall.
i have put a new fuse in the hoover and this time it switched on ...however there must be a problem somewhere ...is it the wiring in the house or the hoover at fault ..
Have you replaced the hoover plug?
Reply to Burned plug socket when i plug in the vacuum cleaner in the UK Electrical Forum area at ElectriciansForums.net
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hello, So I noticed my fridge had lost power, disconnected it and tried a hoover in the same socket and this also wouldn't work. I tried the...
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
Hello My dear old mother tried to clean the tiles in our utility room by using a damp rag and I think some water may have dripped into our plug...
4K
I’m welding and have a cable blue 2.5mm 3 core 10metwrs to reach my shed the plug and socket I got to wire on them biggest hardware has says...
4K
