Discuss Buying my first tester... in the Electrical Tools and Products area at ElectriciansForums.net
Stuart27
Trainee
I'm coming towards the end of my level 3 training and in the market for my first MFT.. There's a ton of different brands and each brand has various products so it's all a bit confusing. Can anybody recommend a good "first" tester?
Also is it worth buying second hand? Since money is a bit tight I'm considering buying a previously owned tester.
Any advice on what to look out for when buying second hand would be greatly appreciated too.
Thanks guys.
If buying 2nd hand a calibration cert would be a must for me.
Also would look for RCD Autotest, ability to test type A and S RCD's. 2 lead loop test. Phase rotation if you need it.
buy a megger 1553 2nd hand, calibrated for under £200.
Thanks for your advice telectrix.
I've also been looking at a second hand Fluke 1652, is there any notable difference between the two? All I can see is that the Megger has Bluetooth which the Fluke doesn't.
Seconded. Type A RCDs will now become more commonplace and some older testers do not have that test function.
Make sure you get a fluke 1652C or 1653B
The standard 1652 doesn't do the full range of tests
Been using a Megger 1735 and because I use my left thumb to press the test button, I often find I’m pressing the jog button instead.
Much prefer my Metrel Mi3215BT.
I also like the Metrel, because it can test B type RCDs as well as A and AC types.
I understand, both Megger and Metrel do a probe which incorporates a test button.
Unfortunately neither my Metrel or the Megger I’m using at work have that type of probe.
...My Fluke has "a remote -test-" lead .. but you miss out on the User is Live ... polarity test warning !
That only surrounds the -test- button on the actual "mft"
I like Metrel and now have their new all singing and dancing 3152 XC, however it is really far too complicated but does everything has memory etc etc.
My first tester was a Metrel Easiplus and it was a really good first tester. If you can stretch to a new tester buy one as you then know where it has been and it has been looked after.
Reply to Buying my first tester... in the Electrical Tools and Products area at ElectriciansForums.net
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
I can't find a previous thread on this topic, so here goes. There is one sort of house-brick that I dread encountering in my area - they are...
Hi everyone, so I'm changing careers from office / marketing and extremely excited to be starting my apprenticeship is September! Joining a local...
Hi all, I am new to the forum. I am currently looking to buy my first multifunctional tester, I have looked at many from seaward to fluke but I...
