Discuss Bypass PDS PRM motion sensor light to Stay ON always in the Lighting Forum area at ElectriciansForums.net
You see it's part of the communal building stairs and I rather not overtly change the appearance of this, hence the question .. but if its possible from what you see in the picture then it will be of great help, else I realize the options are limited.
A 1g 1way switch between Com and L1 either in place of the switch or in the circuit but the light will be on until the switch is switched off if that is what you are trying to achieve.
If you change dip switch 2 to ON then, (if it is dark enough in the stairwell or you adjust the lux level down) it will be on for four hours irrespective of the sensor, however it would need to be reset after the four hours or would not operate, so probably not sensible.
Other than that you would have to rewire to bypass the switch and waste a lot of energy having the light on 24/7 and risk the wrath of the building owner in changing items that should be under their control.
Generally there should be no need to have the light manually operable unless it is not working correctly.
Reply to Bypass PDS PRM motion sensor light to Stay ON always in the Lighting Forum area at ElectriciansForums.net
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
On either side of my front door is a motion sensor wall light - it looks like both lights operate from one light switch inside the house. The...
My 4 year old son won't go to bed without the light being left on and insists his door is closed when I leave. When the door is opened later to...
Our electrician inexplicably wired outdoor floodlights attached to side of house over driveway as "always hot", no switch. We don't want them...
I’ve got a basic PIR motion sensor that I’m wiring into my garage just before the ceiling light. I’ve fitted it all fine and it works, however...
