Discuss cable behind polystyrene plasterboard in the UK Electrical Forum area at ElectriciansForums.net
Evening guys.
T&E with plastic capping. Is this ok behind polystyrene plasterboard or does it still require to be tin? Getting conflicting messages from the suppliers.
Regards, chris
Both types of plasterboard will react with with standard PVC cable..
You can use either type of capping to protect the cable.
there is also some non migratory cables on the market that don't react
They changed the chemical makeup of the polystyrene used for building BS insulation purposes many years ago now, because of the plasticizing effect on cables and some types of pvc pipe. It shouldn't now be a problem, though many are still not convinced!!
Reply to cable behind polystyrene plasterboard in the UK Electrical Forum area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
A silly fault in a circuit only 4m long is currently eluding me! This is ECIR remedials of a landlords supply in a block of flats. Circuit 2 =...
Slightly strange one this, replaced a few socket fronts in a dining room today, all wiring original but new plasterboard on a studded wall. Its a...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
