Discuss Cable Calculation for 2x25mm XLPE SWA in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Good evening all.
Just wanted some advice on a cable calculation,
How do you calculate the carry capcaity of a circuit when there are two cables suppling a DB, we have 2x25mm XLPE SWA cable suppling a DB, just wanted to know how you would calculate the carrying capacity of these two cables?
And of equal length. Also same cable route with the same derating factors.
Reply to Cable Calculation for 2x25mm XLPE SWA in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
Hi All, I'm new to Amtech/Trimble and I've been asked to review a model. I'm looking at circuits that are SWA cables using the armour and an...
