Hi,
When choosing a cable, you should focus on the installation conditions. Derating factors can significantly change the base value of current carrying capacity. Are there any loaded neighboring cables or communications?
In any case, initially the cable was selected at the limit, without current margin. Next is your case without correction factors:
and the report ….
Can you clarify the installation conditions and the effect of the loaded neighboring cables?
