Discuss Cable selection on boat for 1000W motor in the Commercial Electrical Advice area at ElectriciansForums.net
bill01803
Hi all, I was asked in the office last night what size cable would be required for a 12V 1000W windlass with a cable length of 14m. I know how to calculate but where do you find the tables for 12V volt drop etc?
you're going to need one hell of a big cable. use resistance per metre from tables, multiply by 14, then V=IR, where I=83A
going to need at least 50mm cable. don'tforget, the warme the cable gets, the higher the resistance and hence increased VD.
Hi,it is a pretty standard install. Use 50mm high quality welding cable,and get someone to sort the runs and containment,correctly.
Long runs of multi-stranded flexible,can be very hygroscopic,and will need correct attention,at terminations.
Make sure the installer understands the word "hygroscopic"....as the yankee spell-check,has failed :rolleyes:
It's the same volt drop table as any other voltage, the resistance of the cable doesn't change.
Other details,i forgot to add,were it's duty ratings. It's not a bow-thruster,so it will have short duty-cycles (all in the MI) and 1000W is the maximum,so majority of use will be way below,at no-load operation.
Anchor winch,would be a whole different basket of whelks...
Well,i suppose it's all relative....
It's forecast a change,to 10,and you need to do a rake of furling and unfurling,to get back to safe waters....
The cable,is an average length of site,MMA welding cable....
I wonder which job,is the one where you thought "Mmmm,i'm glad i spent that money..." :)
Just the job for me indeed...provided it's Capstan Full Strength!
However, just for clarification, is this an anchor windlass or a furler we're talking about? Clearly, the Lofrans linked to above is the former...
Reply to Cable selection on boat for 1000W motor in the Commercial Electrical Advice area at ElectriciansForums.net
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi everyone, I'm looking to do some cable runs for cat6 etc in my house and was looking for some advice on blind wiring. I'm not skilled but I...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
Hi, go easy on me please, I've just returned to the trade, well I am about to, I received my Gold Card last Thursday. I've been gen'ing up for a...
