Search the forum,
Discuss cable temp factor for 70/90 degrees cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
bullybully45
Hi,
I'm in the process of trying to do a "monkey sheet" to enable my apprentices's to make correct cable size calculations. I'm happy about the use of the 1.2 factor used for 70 degree rated cable but I havent come across the 1.28 factor for 90 degree cable before. I would be most grateful if anyone can give me iformation on this and where I can look it up and read about it.
Cheers
Reply to cable temp factor for 70/90 degrees cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In preparation for an EVSE installation, I am running the supply cable from the main CU, via catenary, to a new CU in my garage. The cable is 6mm...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hello I’m going to install a hard wired 230v security camera, incorporating floodlights, outside and above garage door onto brick. An exposed...
I've been told I need to upgrade the main earth bonding to 16mm. The consumer unit is on the wall adjacent to the externally mounted incoming...
4K
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
