G
GeeTee266
Looking for some cabling advice for my garden project.
I’ve put together this diagram below, which hopefully explains what I’m trying to achieve.
(FURTHER INFO AND QUESTIONS BELOW DIAGRAM
GREEN – Garden fence lights (1.5mm 3 core cable)
9 x led lights on fence (including 2 on outside of our walled gazebo. I’m thinking of tapping into an outside double socket and chasing the cable of the wall and placing a Wi-Fi enabled light switch on the wall inside the house, allowing me to control the lights from an app. (I’m running the external wall lights attached onto the house, using the same Wi-Fi enabled light switch and app and it’s been working flawlessly for a couple of years.)
YELLOW = Gazebo (4 or 6mm 3 core cable)
I intend to fit 2 x wall mounted electric 2000w patio heaters in the gazebo (16amp draw each). I’ll also have 3 x LED ceiling lights and 2 x double sockets.
RED = Sauna (10mm 3 core cable)
I’ll fit a 10.5kw electric sauna heater with a 48 amp draw, as well as a couple of LED lights inside
ORANGE = Front garden lights
6 x led lights on fence. This will run directly from the main fuse board and I’ll control them with a Wi-Fi enabled light switch on the wall inside the garage, allowing me to control the lights from an app.
BLUE = Shed
In here I’ll have led lights and a double socket.
QUESTIONS:
Any other comments or help would be much appreciated.
BLUE = Shed
QUESTIONS:
- Can I run just one cable from the main fuse box down into my shed and then fit a garage consumer unit and then run the sauna and gazebo on separate cables from that point?
- If it is possible to run just one armoured 3 core cable from the house to a consumer unit in the shed, do I need to make sure that that cable is large enough (i.e. 16mm) to accommodate the total amp draw from all items downstream? (e.g. sauna + gazebo). Or does it not work like that if I'm using a separate consumer unit in the shed?
- If that’s not possible, do I need to run 3 separate cables from the house (1 for the shed, 1 for the sauna, 1 for the gazebo)?
