Discuss Can anyone explain this reading (suspected open circuit) in the UK Electrical Forum area at ElectriciansForums.net
Alright troops ! First post here ! Any one come over this situation before !
Yesterday i connected an existing feed for cooker good into socket but it wasn’t working when I turned on!
I tested between live and earth (240v) between live and neutral (12v ) and neutral and earth (0 volt )
I suspected the neutral was an open circuit, I rewire a neutral and that worked!
I can’t think why there was 12v between the L and N
thoughts ?
Test meter impedance was high enough to see 12V with capacitive leakage !
(That would have disappeared if a little more current was drawn)
( Both terminals at 240V .. No Neutral .. 0 V on meter , Ooops )
Reply to Can anyone explain this reading (suspected open circuit) in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi. I've read much about ac vs dc but can't find a 'simple' answer. If current alternates 50 times per second in a uk mains circuit, why do live...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
A client has a Kenwood CK405 dual fuel range cooker, for which the smaller of the 2 ovens doesn't work. The elements tested out fine, but live...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
