Discuss Can anyone identify this consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Rupert
Any idea what make this consumer unit is please.
All above are correct. CGD, which are now owned by and branded Lewden. They also are sold through Denmans as their own range (curve or steeple rings bells) Although I don't have any local Denmans so don't know for certain.
Lewden cheap rubbish. I hate them boards to hard can it be to make a board where the rcbos sit straight
I moved to fitting these a couple of years ago as an affordable RCBO option. I have to say I don't have breaker twist problems like in the picture. Just doesn't see to happen for me.
I am, overall, pleased with the quality but will admit I am currently weighing up other brands due to other factors.
Reply to Can anyone identify this consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
