Discuss Can I use a 32 amp rcbo on a radial circuit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yr ys
Hello
Is it OK to use a 32 amp rcbo on a radial Circuit. Cable size is 6mm2, cable length is about 15 m. There are 4 double plugs on the circuit. Loads are kettle 2.2 kw, washing machine max 2 kw, electric cooker 1 kw.
Cheers
Reply to Can I use a 32 amp rcbo on a radial circuit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
  • Locked
5K
