Discuss CAT6 points in house in the UK Electrical Forum area at ElectriciansForums.net
Looking at putting some CAT6 points around the house for various TVs, Xbox’s, Laptops, all I have at the minute is a Sky Hub (router) what would be best way to do this? Never done Data before am I looking for Patch panels, TP-link?
Just looking for best way thanks
External cat6 up the outside of the house, drill in and surface or flush box in the room. Black external Cat6 is not ugly and darn site easier if decor is good indoors.
You can patch or switch from that point.
So from Sky Router from Ethernet point (has 2 Ethernet points) to new Ethernet switch? Then just to each room with CAT6
I’m also looking for some cameras could I take a link from Ethernet switch to DVR then from there to cameras?
spare port of router>patch lead into a network switch (however many points you are planning of have in the points is the number of way network switch you need maybe get a few spare)
then cat6 from network switch to the various points in the house
(either punched into a cat6 outlet plate if chasing into the wall) or terminate the cat6 end off in a rj45 and plug straight into the TV, xbox etc
if your planning on have quite a few points- then having a network work cabinet with a patch panel would be a neater more professional finish
Thanks for that so much clearer
Sky Router needs to be set to modem mode then a cable from the Sky Box to your switch, I would install a patch panel where all the points are terminated to from the rooms then patch them in to the switch, you can either install a POE switch if you want cameras or a POE NVR to run the cameras.
Thanks I forgot about modem, so what’s the best way to do it as I want points in each room and cameras and the cameras from an NVR? So where would my points in each room go? Would I need a switch for them and then a POE NVR for cameras? So a switch that links to POE NVR?
Depends what make of CCTV you go for, Hikvision sell POE NVR's which I have, I also have a couple of 8 port Ubiquiti Tough Switches which also provide POE, as I am on Virgin I switched it to Modem Mode and then connected a Netgear R6400 to it so that handles the Wireless and DHCP side of things as well as firewalls etc etc and is then connected to the Tough Switches.
Ok thanks so if I go for some kind of POE NVR for the camera side then just get a normal switch for all the points in the house, unless I go for a POE switch then run everything from there and just link to a NVR which will do cameras?
Yep, but sometimes it's easier just to run the cameras from the NVR, how many cameras do you require and what is your budget?
6-8 cameras and no budget I’ve seen you can get a switch that does non Poe and Poe, just looking for best way to do cameras and data points in house
Reply to CAT6 points in house in the UK Electrical Forum area at ElectriciansForums.net
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
I am wiring a garden room which will be a home office, customer wants wired ethernet points and wifi down there from the house router Its too far...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
Hi all Now being upfront I am not a sparks. I am about to have some work done by a friend (certified) and as he is doing me a favour I want to as...
Evening All Please go easy on me as I am new to this and attempting to do this myself. 😬 I am currently building an outhouse at the back of my...
