Discuss CAT6 points in house in the UK Electrical Forum area at ElectriciansForums.net
But also it’s proberly easier all cams from NVR just not sure how to do data points in house
Usually cascade down from top to bottom, you can have the Sky unit anywhere set it to Modem Mode then run a cable to a switch say in the loft (run a spare cable as well) and have your patch panel there where you terminate all the cables from the rooms, if in a room say where the TV is you can always just add another switch say 1Gig as you won't be caning the data rates.
You need to work out what goes where and the size of the house as you may need a wireless repeater to boost the signal as to be honest most devices will be wireless, I just checked my stats and I have 31 devices connected, sad............
CCTV Kits | CCTV Systems | Trade CCTV | CCTV Seller - http://www.cctvseller.co.uk
As Sparky Chick mentioned it reduces the loading on the rest of the network as you will have a constant stream of data to the NVR, let me do a diagram.
NAS is a network storage unit if you need one for backups etc etc etc the one above the Sky box is a switch with wireless capabilities, like I said I use a Netgear R6400 from the Virgin Box to handle the DHCP side of things as well as the main wireless network and the guest network and other stuff as well, the POE switches that I use are https://www.broadbandbuyer.com/prod...s_uXbAJsbHnt5S_eW4OHiX9ULEtFLd1hoCbOYQAvD_BwE
Just got used to them and have a few dotted around, when I do refurb the house then I will change things around as mine is a bit of a mish mash as one switch is used in the living room another elsewhere etc etc.
Reply to CAT6 points in house in the UK Electrical Forum area at ElectriciansForums.net
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
I am wiring a garden room which will be a home office, customer wants wired ethernet points and wifi down there from the house router Its too far...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
Hi all Now being upfront I am not a sparks. I am about to have some work done by a friend (certified) and as he is doing me a favour I want to as...
Evening All Please go easy on me as I am new to this and attempting to do this myself. 😬 I am currently building an outhouse at the back of my...
