Discuss ceiling fan light only comes on if fan is on in the UK Electrical Forum area at ElectriciansForums.net
brimfield
we are replacing 2 ceiling fans. I wired the first one in and for a dual switch hook up they have the standard white to white black to black and the grounds. but for the light they have a blue wire that goes to the red traveler wire coming in., But now to turn on this light I have to have the fan switch turned on. The light will go on and off from the light switch with the other fan but only if the fan is on.. Should the ceiling fan blue wire go to the black hot and the black from the fan go to the red traveler wire.
Reply to ceiling fan light only comes on if fan is on in the UK Electrical Forum area at ElectriciansForums.net
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
My ceiling fan does not have light. couple of weeks the light started blinking then it went off. I did my search and everyone says that I need to...
