Discuss Ceiling heating...1970's? in the UK Electrical Forum area at ElectriciansForums.net
The ones in the estate near me looked a bit like those heat mats used by reptile keepers. There was the plasterboard ceiling,heat mat,polythene vapour barrier over and then a layer of rockwool about smoke paper thickness. On the underside of the ceilings in every room were stickers warning of the dangers of piercing the ceiling!
I remember a relative of mine had it in their place, if you stood on a step ladder the top airspace of the room was lovely and warm i.e 1ft below ceiling height, but the rest of the room was chilly to say the least and it was of a time when fire places were being phased out of new builds, so this was the only heating in the property. Rubbish!!
I can't for the life of me imagine how they could possibly work if they're not radiant. How was the heat supposed to reach the people below? Did they maybe have some kinda forced circulation fan? Sounds like the result you get when you let the marketing department get involved in R&D.[/QUOTE]
I came across this system on an estate in West London area , The name of the system was called ESWA , basically as you said elements in like a foil with insulation about 5mm thick , a lot of these system have packed up , and expensive to run , as these places are all electric the alternative is storage heating , using the existing off peak supply and install a new consumer unit and new circuits and heaters, ditch the old off peak circuits completely , done quite a few flats in that estate, about 70s /early 80s built..
...as these places are all electric the alternative is storage heating , using the existing off peak supply and install a new consumer unit and new circuits and heaters,
We did exactly the same. We converted a sheltered housing place about 20 years ago that had ceiling heating. We used the existing radial circuits to feed storage heaters from a new off peak board.
Thats all you can do really , the flats on the estate I am talking about were very small , so I suppose the old heating system was justified as storage heaters took up valuable wall space , I went round on behalf of the managing agents doing that , another system thats come about that may be of use is the electric boilers using wet system with rads , I have only come across one of these but I don't know what the running costs are ,..
I remember having a conversation with a rep about those "electric wet systems" a few years ago,they were also doing a lot of publicity in the likes of PE magazine,the guy was saying they were very economical however I wasn't convinced,by and large anything that involves the words electric and heating in the same sentence is usually costly.
I would like to know what it does cost to run for myself , I need to replace an oil fired boiler and needs to be relocated as well , and that means moving the oil tank , so an electric boiler would be an idea , but with a 4 bed house I think the running costs would be massive , I have looked up Heatrae Sadia they do one , but running costs I think would be massive , If anyone has any info let me know please,
bet the councillor that decided ( via a brown envelope, nudge , nudge ) to use it got a golden handshake and a huge pension, then went into banking.
Reply to Ceiling heating...1970's? in the UK Electrical Forum area at ElectriciansForums.net
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi. I am trying to replace a heating timer with a smart switch. The current timer is the type with a dial on the front and 1 to 24 written on it...
Hi! I'm in a new build home that has had a lot of construction problems, & the builder has done really substandard work in many areas. My current...
