Discuss Ceiling lighting wiring in the Lighting Forum area at ElectriciansForums.net
Wic4it
DIYer question!
This is my existing wiring. 3 x neutrals?
my new light fitting has one x neutral and 2 x live connections
please can some one tell me how to wire the new fitting correctly?
I
266cfdbc-8e48-4c39-8282-d0e058ce5ac6-jpeg.60760
Can you show the terminals of the new fitting. The wiring at the rose is missing any earths unless the wiring system is using a conduit system.
Hi please see attached new terminals. I’ve connected the blue and two x black into the neutral and the live cable into the live one terminal. Only 2 out of the 5 bulbs light up!6F079B0B-40F5-4019-87D3-AF54C2550D80.jpeg
That fitting needs an earth. Can you show the wiring what was under the ceiling rose. The reason only some have illuminated is that it has two live terminals.
this how the rose was wired. With no earth?
I’ve put the 2 x black and 1 x blue into the neutral on the new fitting and the 1 x red live cable into the live 1 terminal on the new fitting. Only 2 out of the 5 light bulbs light up.
Can you show the wiring under the ceiling rose. I know why it isn't fully lit the big issue is an earth.
Reply to Ceiling lighting wiring in the Lighting Forum area at ElectriciansForums.net
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
A
the situation is this: 8 x 24v rgbw flood lights for a garden, each fitting has power consumption of 45w. 3 lights into a 200w driver, another 3...
