As des and mudock has stated plus , if you are changing the consumer unit im asuming from a fuse type to a dual RCD / RCBO board, then what you are doing is improving the safety of the installation , when this type of work is carried out you are required to completely test the installation , so what i would do is do some basic tests so faults can be identified IE shared neutrals low insulation readings etc , the other thing you must do is to install the bonding to the services gas oil water structual steel etc , the times that you should also rewire are when the installation is VIR , Lead braided paper insulated singles etc , also when the general installation is in a poor condition but initial testing should verify this also this type of work is notifiable to the LAB
