Discuss Change standard batten light to 3no LED spots in the DIY Electrical Advice area at ElectriciansForums.net
RichardA
Morning,
First post... apologies...!
Currently got 2no LED batten-style lights in my garage, all wired in by a sparky about 6 months ago. 1 serves the front of the garage, the other the rear (and the garage is divided by a partial stud wall). The rear half ceiling insulated and boarded over. Separate DB in the garage etc...
Can I swap the rear single batten for 3no IP44 rated LED spots? The drivers on the spots allows for in/out cabling (ie really easy) so wire them one offer the other in a chain?
Experience level - replaced spots like for like in the house without any issue... sounds obvious / simple enough to do?
Thanks,
Richard
Don't see why not but current Regulations will require the alteration to have additional 30ma rcd protection.
Thanks, will see what was/is installed when the rain stops - my sparky wired in such a way as I was going to re-install the batten anyway (once I'd put the ceiling up) so may already have RCD in place. If not, then I'll leave it for the time-being; I'm not wishing to break any rules for a change.
Richard
Reply to Change standard batten light to 3no LED spots in the DIY Electrical Advice area at ElectriciansForums.net
Hello, I’m boarding out my loft for storage and I’d like some decent lighting up there rather than loft lights I’m currently using. I purchased...
4K
I am upgrading garage lighting. I have installed 12 40W batten lights (cheap Amazon variety - don’t have specs). 6A breaker in Garage consumer...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
