Discuss Changed socket but still no power in the UK Electrical Forum area at ElectriciansForums.net
Jonebb
My Fridge Freezer power was lost so I first changed the fuse, then I tried plugging it into another circuit which worked.
I bought a new electrical socket, but still no power from that socket?
Any ideas?
There's been no tripping of RCD or any other electrical issues.
Are there other sockets or FCUs on the same circuit (the same MCB or fuse) at your consumer unit, as the circuit with the socket that doesn't work? If so, are the other/s still working?
Thank you for your replies - the socket is on a different circuit to the one tested. The Fridge socket is on the same circuit at the boiler tap...which seems strange. Just need to look behind kitchen cabinets to see where it goes.
Are you sure that their are no other rcd,s hidden away in awkward positions, behind cupboards or shelfs / box's ?
Neighbour had a small CSU in the kitchen above the units with top pinto in the way which would trip every often as it fed the out door lights and pond pump which when the filter got blocked tripped the unit, he was 70 and worried about climbing up a ladder to reset it.
Any ideas?
Is there an additional supply, such as a fused spur?
Reply to Changed socket but still no power in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go...
