Discuss Changing Roller Shutter Switch in the UK Electrical Forum area at ElectriciansForums.net
HJC
Hi everyone,
Need advice on replacing roller shutter key switch with a regular up/down switch
Client doesn’t want the key switch and prefers a rocker. Would this be a straightforward swap? Or should I leave to the roller shutter crew.
Something like this is what they currently have installed
a 3 position retractive switch should do.voltage and current ratings being OK.
Also I have a few customers who have had to change their emergency stop push buttons for a key switch for insurance so when they leave they can lock it off shut down!
The purpose for keys in E-Stops is in no way, and should not be allowed for isolation of plant or machinery.
It's purely there for diagnostics. So an operator can't quickly jam the estop, reset the push button and claim ignorance to the fault.
unfortunately two of the customers who swapped their buttons were broken into and the loading door opened so a van could back in to load the I'll gotten gains. Insurance company said they needed key switches somewhere. Usual door fitter mentality the isolator is 4.5m up next to the shutter control box so that was the simplest Work round!
Reply to Changing Roller Shutter Switch in the UK Electrical Forum area at ElectriciansForums.net
Hello Everyone, (NOT DIY JOB, Need advise prior to calling an electrician on site) Is it possible to swap a 3 phase rotary switch (roller...
Hi Everyone, hoping someone will be able to help me decipher the wiring for this hoist controller. the handset it came with has stopped working...
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
