Rockingit
Mentor
I need to joint a 2.5/3 SWA to a 1.5mm HO7 then bury it. Don't need to worry about glanding the armour as it's good the other end (I suppose I could bond it to the cpc if we're being picky).
A 'proper' expensive IPX7+ box is a bit OTT for the job, and a SWA joint kit might not like the twiddly 1.5mm. Was thinking about just using some strip in a small adaptable box then filling it with resin?
In the past I've used a plastic adaptable box.
Gland off the SWA as normal, the use a stuffing gland for the flex.
As you say, fill the box with resin, either with the lid off, then quickly put the lid on, or fill through a knock out.
Make certain you wear gloves.
That's what I figured, in which case the job's an easy one as that's exactly how it's currently connected on a post above ground! Right then, anyone got any gunk on the go?
I'm going with spin. But make sure the armour is bonded through, you never know what could happen to the cable in the future.
I have done what you are doing in the past and used a tin of fibreglass resin from a car repair shop cost about £8 but dont use all the hardener as it can get quite hot during the curing process.
Rockingit,
Guest111,
