Discuss Clamp meter that will measure milli amps in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all. I’m looking to invest in a clamp meter but want want that will measure milli amps (nuisance tripping etc). The megger 305 seems the best about; is there any others out there? TIA.
look for the resolution. think it's 0.1mA which is fine for tracing earth leakage.
So is that one any good then?
You get what you pay for.
(Drop unknowns on the floor = drift)
( compare with a "Known" situation at home for some stability )
But you could pay for quality - and have it banging about in the van -little used for years !
(With all this DC type RCD/RCBO changes ,I'm still unsure what is around the corner)
@Haworth
Just in case you didn't realise, David is having a bit of fun with that recommendation. Don't clamp a 771 around an AC line, it... won't appreciate it.
As for AC leakage clamps, I use an AEMC model 565. It has a high range to 100A AC, low range to tens of microamps.
View attachment 51091View attachment 51092
I use one of these. Being able to move the clip separately is handy. Just make sure it pointed in the right direction. I often couple it up with the other one for signal faults, Fluke-709 | Fluke 709 Multi Function Calibrator | RS Components - https://uk.rs-online.com/web/p/multi-function-calibrators/7769529/ . Very handy if you carry out fault findingView attachment 51091View attachment 51092 on your own.
just seen the price.could buy a van and a MFT for less.
My current clamps are :
fluke clamp 1:1000 ratio producing 150A from150mA DMM output
Fluke 360 reading from 1uA to 60A brilliant for tracing fault currents.
If you haven't the money for Meager or Fluke.
This Martindale is a good all rounder
I believe this guy sponsors the forum and he even gives an added discount to members.
The unit you’ve linked to costs more than the Megger DCM305E
Reply to Clamp meter that will measure milli amps in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hi all I don't appear to be able to post in the DIY forum so apologies if this is the wrong place. I live in a block of flats with an external...
