Discuss clarification on earthing on a CU change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
O
oldtimer
Hi all can you give me some clarification on earthing when changing a CU.
1. Do you have to upgrade the main earth to the water and gas pipework to 10mm or can you use the existing 6mm.
The reason I ask is that I am getting conflicting reports saying yes you do o no you dont ? .
2. Can you loop say a main earth from the water pipework to the gas pipework.
3. Main earth from DS should this be 16mm or can you use 10mm.
you always will get conflicting views.
personnaly i would always upgrade unless it is too difficult and customer dont want upset, however as you would be responsible then you would need to be able to prove it was suitable if needed and in any case only on tns or tt and min 6mm would be allowable.
main bond not main earth can be one fom gas to water as long as its continuous (one unbroke length)
same as above for main earth providing you can prove it then as the electrician its your decision your name.
General rule of thumb is and as i understand it.
Main earth cable must be minimum of 50% cross sectional area (CSA) of your meter tails. Bonding cables must be minimum of 50% CSA of your earth cable so :-
25mm supply tails
16mm main earth connection
10mm main bonding
6mm equipotential.
This is of course decided by the rating of the cutout fuse, and assumes 100amp.
At 80 amp it is compliant if
16mm supply
10mm
6mm
4mm all as above.
It is good practice to upgrade to requirements for a 100amp cutout fuse as this makes it future proof for now.
If it isnt practical or possible to upgrade any bonding then a 10mm main earth connection, and 6mm to water and gas etc is acceptable but must be noted on the certs and a clear reason why an upgrade was not carried out.
Hope this helps,:cool:
Cheers..............Howard
you can always crimp the main bond before the gas pipe, loop through gas clamp and then on to the water, providing it is suitably sized of course.
Thanks SirKit
This is exactly what I thought but was getting confused with regards by the main earth should not be less than half the size of the main supply cable ? surely this should read dependant on the size of the main fuse.
For example a flat or house has a 60 amp supply fuse but the spark who fitted the existing board or the supplier who replaced the meter and was nice enough to replace the old VIR cable on the consumer side put in 25mm tails because thats all they had at the time no problem their but does this mean you have to comply and upgrade the earth to the gas/water from 6mm to 10mm my reasoning here is that when you are quoteing to replace a CU then upgrading to 10mm can impact on the cost and time to do the job.
Reply to clarification on earthing on a CU change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Morning guys, Just been to look at a CU change and there was a bit of an oddity with the PME connection in the old black cut out. Looking at the...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
