Don't think Im going to take any further unless the client wants is the SWA.
And i am part p registered. Just thought there could be another way round it without SWA.
That's good to hear, you get too many cowboys these days.
Don't over think it, swa is the best choice you know it, don't put your name to crap just to earn a quick quid
Probably better installing your own stuff than using exisiting if you dont know what your at, maybe you do and doubt yourself,
be good if you had friend who is spark and come have look and give you advice... Its hard for us to judge from here what your really at and what is best way around it. But ask questions till you at least get same answer twice.
Cheers for the help. Was trying to find a simpler solution and should have just gone with instict to use the SWA. i will ask a spark mate and find the best way round it.
It all gets easier in time, but will always be something new to baffle you. I take chances on jobs where im not 100% sure of, but over last few years ive met some good sparks who are more than happy to help me cause i work for them sometimes for a low wage...
Ps im still doing nvq year 4.
After a proper inspection the pipe i thought was conduit was infact a copper pipe which i.could see between the garage and raised patio. Under the floor boards i don't know what there assuming just fed under floor boards(in the.house) and drilled straight through the wall of the garage and wire straight through garage wall; with old wiring still intact.
I may have been able to make a contribution to this thread,but that sentence has dulled my senses
IWhatt i mean to say is.
from ccu there is a pipe that i thought ran through to the garage but i dont think that it does.
so u have ccu in cupboard under stairs in the house(with conduit/pipe protruding from the floor) >hallway >lounge >raised patio outside >then garage.
between the patio and the garage i see a copper pipe. and dont know if it runs all way through the house to the pipe i see in the cupbourd.
If that make anymore sense?
You could always go overhead, over the crossing and down the garden fence etc ... i would try and avoid digging up a drive unless its out of the way..or a mole and some ducting..hard to say without seeing it ..
if there is a street light nearer, just tap off there ...lol....KIDDIN
Can i go over overhead? didnt know was poss. It would be a lot easier than going and digging up the drive. What i use to cross the gap??
it can been hard to help, coz some jobs u need to be there to see for yourself,
I understand it can be hard to help and to explain certain jobs. but im finding it useful to talk to other sparky and get a better idea of how things can be done. any help is better than no help.
What is the span, will there be vehicles passing under the proposed span?
Page 128 of the on site guide has some general info
