Search the forum,
Discuss conduit factor in the Australia area at ElectriciansForums.net
hi have a query re conduit factors hope someone can help.
OSG gives values for straight conduit runs between boxes, and values for conduit runs with one or two bends.
for example
if you have lets say a 1m run to a 20mm elbow box and then a 2m run to a socket outlet.
would this run would be classed as 2 straight runs, one of 1m(between boxes) and 2m (between boxes) respectivly or would it be classed as a run of 3 meters with one bend (between boxes). in other words is the elbow box classed as a bend in the conduit run or as a box.
hope that makes sense.
Reply to conduit factor in the Australia area at ElectriciansForums.net
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Looking for some advice; I am intending to mount two led downlights on pillars/brick walls either side of the garage door opening. I will drill...
Hi! I’d like to install a pedestal-mounted (230 V, 30 A max - programmable) EV charger close to my driveway, which ends about 12 feet away from...
4K
