Discuss Conduit on wooden fence in the UK Electrical Forum area at ElectriciansForums.net
Doomed
I know that conduit on wooden fence is bad practise, but where does it atually say this, and is it just bad practise or a no no?
(25mm conduit feeding a garden shed, saddles approx 1 foot above ground level)
I would say it would be fine too, but as above, I don't know every reg going so may be wrong. I have certainly seen it many times before. Make sure it is well supported as conduit seems to sag more outside, maybe due to weathering and temp changes.
What sort of wooden fence by the way ? if it's lap panels then you're not really going to have much to fix to. If it's half inch thick timber then you should be fine.
I think no wiring on fences is an NICEIC idea since the fence will not last the length of time that the wiring system is designed to last (30 years or so!), however so long as the fence is supporting the conduit then there should be no problem, remember to let the neighbours know not to paslode the other side of the fence!
Reply to Conduit on wooden fence in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
