Discuss conduit used as cpc in the UK Electrical Forum area at ElectriciansForums.net
B
Buzz-light-bulb
Hi all again
I'm doing another condition report for a property, no cpc for sockets, cooker lighting, what's the best way to test continuity, I'm thinking of doing the same way as R1+ R2 line to earth terminal, also would you record results in r2 box or R1+ R2 box, I'm having a bad day
It's fairly small property, and basically it's got new consumer unit (plastic) and there's a steel adaptable box behind it where all the conduits are connected and this is earthed via a 6mm conductor which connects into cu earth terminal so I'm abit limited
Reply to conduit used as cpc in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, I saw in the hospital every circuit has 2 separate cpc, same size, sometimes different. I'm wondering. How we can do the dead...
Have been asked to do remedials on an EICR that was carried out a year or so ago by another electrician. Curious to know what code you would give...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Electrical2Go now stocks a selection of Super Rod products, designed to help you save time on cable installations and more! One of our best...
