Search the forum,
Discuss Connection earth cable to banjo in the Australia area at ElectriciansForums.net
I like using gutter bolts with the lug sandwiched between two washers then a spring washer then the nut :) .
You just jam it in the strings.
If your going to do it correctly you will use cable lug with 1xbrass bolt/setscrew 2xbrass washers 1xbrass nut &1xbrass locking nut ,you could use sheradized /yellow passivated but brass is easyer to get hold of.
Once had to go to a job to remove all roofing bolts from banjo,s (100,s of them)because insurance company stated it was technically not acceptable ie dissimilar metals
yours benji
Reply to Connection earth cable to banjo in the Australia area at ElectriciansForums.net
