Discuss Conservatory recessed ridge lighting.... in the Industrial Electricians' Talk area at ElectriciansForums.net
sythai
Just seeing if any of you chaps wire up many conservatories....?
And was wondering if you may have come across any recessed ridge lighting before ?
Was speaking briefly to someone today about the possiblity of some work coming up... and he said the conservatories they build can come with the ridge lights pre installed/wired ?
Any ideas....
Thanku Sy
Any ideas....
Thanku Sy
I've never seen any recessed conservatory lighting, I suppose you could create something on the capping of the ridge but probably only LED to allow for poor heat dissipation in such a small recess.
Anyone else seen this?
Well it's got to beat those awful fan things that most go for!
Had fun fitting one of them before and like you say didnt look to great after all that effort...
reckon fluro would look nice though, quality job..
There is not much space to recess anything into the ridge of a conservatory certainly not the ones I've wired, it's bad enough trying to hide the cable upto the ridge on some
If a customer required concealed lighting I'd probably look to use some T5 fluorescent tubes
Reply to Conservatory recessed ridge lighting.... in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
Thank you in advance for your help. I recently purchased a home and while removing some built-ins I found that they had a 14/2 wire running...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
