Discuss Consumer unit above boiler in the UK Electrical Forum area at ElectriciansForums.net
Ampo
Hi all, I want to move a consumer unit and the best place is above a combi boiler. It is 200mm above and will be incorporated into a cupboard with the combi. It seems like it would get hot but I cant see any heat whatsoever coming from the top of the combi so assume this all flues out the wall. I cant find any reg saying i cant do this either. Just looking for some common sense, bad idea or not a problem at all?
Regulations aside, I would make sure the consumer unit is easily accessible to work on. So avoid a deep cupboard, anywhere too high or awkward to access, anywhere that has lots of hot pipes to keep accidentally touching, plenty of room to remove the lid, etc.
I don't know where you are, but the foreign building regulations (England and Wales) part M requires that cu are placed 1350-1450 above floor level, this is also advised in part P.
Not specific to a Boiler of course, but cu are supposed to be accessible in order for the homeowner to access the switches /mcbs and the 6mth testing of rcd
...any plumber seeing a CU that close to a boiler will have an uncontrollable desire to block all access to the CU with new pipework.
Here’s one from our friends in the USA :) .
Thanks guys, the question was more from a heat point of view. The boiler is a combi, if it had any heat on the top I wouldn't consider but seems to be cold when running. It's my own house and the boiler is new so no pipe work issues. Part M dosent really come into it imo as this board will be moving over a couple feet to make way for a steel rather than it being a new build. Maybe if I put a timber dividing in the cabinet so it's not strictly in the boiler cupboard but you access both when opening the door. It will likely end up being incorporated in the kitchen units. Problem I have moving it further is it will be increasing the tails length that already come up the wall in the soil pipe boxing and I dont really like running them further than needed
There is a limit to the length of tails you might need to look at.
Someone else with a decent memory will be along shortly to advise.
I second what others have said. No problem, as long as there’s adequate access to the board for maintenance.
What about this this.....if you want to lower the ceiling...…….
Reply to Consumer unit above boiler in the UK Electrical Forum area at ElectriciansForums.net
I went to look at mess this morning. S plan heating system, google nest heat link in airing cupboard. Downstairs in utility room the kitchen...
Hi, my wife and I have decided to bite the bullet re the costs of an electric combi boiler in an off-gas grid one bedroom flat where space is so...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
