Discuss Consumer unit change in the Commercial Electrical Advice area at ElectriciansForums.net
saxon
I’m only an apprentice and of course, I’ve curios about a lot of things. I was in my friends house recently, who is getting an electrician to upgrade there, rather old, consumer unit up to 18th edition standards.
I had a look, out of curiosity and seen this (uploaded a photo) and I was curious on how to make the board fully dead as there isn’t an isolation switch for what I can see as the meter tails go to the bullet? And obviously I won’t be pulling that out.
My main question is, how would I fully isolate this board?
Thanks for your help
Us us down south have yours them up north as the same DNO, I believes with slight tweaks.
Down here, down south, SSE allows Scheme members to pull main fuses with abandon, following certain criteria. Dunno how that pans out in bonnie Scotland, but you could enquire with your DNO.
Pull the fuse. It doesn't even have a seal on it.
No... I don't see a seal... never had a seal as long as I remember.....
Just phone the supplier, ask them to fit an isolator. Might cost a little bit, but makes life easy for the sparks.
Is that the going rate for an apprentice these days? A tenner?
and what did you buy with that? A big box of Jaffa cakes? Good man.
Ps... who took the front off the board? naughty naughty.
£160 in Bristol for DNO to fit an isolator. If you buy wylex isolator and put it up ready with your tails in they will happily connect to that. The isolator cost £23 bit of a saving eh?
That earth is picked up from an old disused supply conduit, by the looks. Something weird going on.
Call the seal fairy
Get the DNO to remove the fuse and fit an isolator in the process.
Customer had to pay 75 inc vat for that last week. Fuse holder looked very stuck and never been moved. So called wpd. They stood and watched whilst i cut tails and put in isolation switch. If they did that bit that was an extra £100!
Wpd will charge 75 per visit so were they to have come back later to reenergise all in was 150.. robbing lot
Reply to Consumer unit change in the Commercial Electrical Advice area at ElectriciansForums.net
Hi, I have a job for a customer, the consumer unit is an old 3036 board and there are several holes in it giving access to live parts, I can...
Hi, NAPIT report was carried out due to flood, all kitchen appliances, wall/light switches, fire/heaters etc need replacing. The electrician...
Afternoon! Hoping someone has experience working on the ABB gear below. It’s in a Mobile Office/ Welfare unit, supplied via either 230v hook up...
Hi everyone. I currently have a level 2 diploma, Part P and 18th edition. Can I carry out a consumer unit change if I work for myself privately?
