Discuss Consumer unit changes in the UK Electrical Forum area at ElectriciansForums.net
W
Welshsparky
What's the going rate for a 10 way consumer unit change with upgraded tails these days? I seem to be getting ndercut left right and centre at the minute!
Unfortunately it's one of those jobs thats very easy to cut corners on.......forget bonding,tails and testing...wack it on as a straight replacement and you could probably do it in a couple of hours including travel....until the rcd trips,in which case you swap it for a DP isolator...keep a stock on the van just in case.......The concientious sparky hasnt got a dogs chance against that.
Your location in the UK has a bearing too.
Yes certainly, london and the south east is generally a little more expensive(especially London probably more £500)
I can usually do a cu change in an easy day, be done by early afternoon and try to fit a small job in on the way home, when it goes trouble free and the bonding is not too hard
I never ask for cash but nearly always seem to get cash payments when doing domestics, suppose customers just assume that's what you want?!
I think thats very reasonable most guys on here are charging around that. When you say £100 less is that actual quote or is that the customer saying that so as to try and lower it? So customers like to haggle as if it's like a boot sale
I got out priced on a kitchen refurb the other week. £300 they beat me by! do you know what, I've not slept a wink since lmao.
If silly fools want to work for silly money then you have only two choices. Leave them to it and possibly clean up the aftermath OR play their game. My sofa and computer chair are far too comfy for that malarky so I go with the first option... Can't beat a nice cold cider whilst reading posts on here at lunch time lol
PS my price is £350 for a fault free board. This includes tails/main earth but does not include bondage... Oh no, an extra charge is applied for that :D
Reply to Consumer unit changes in the UK Electrical Forum area at ElectriciansForums.net
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
