Discuss Consumer Unit on Stairwell in HMO in the UK Electrical Forum area at ElectriciansForums.net
Evening all. I am quoting some alteration work in an HMO where they are adding 2 bathrooms and a bedroom.
The main board is down in the cellar and there is a sub board on the 1st floor landing in the stair core. Its a 'Steeple' board I believe a Denmans branded board. It is in a bad way, front not fitted properly and blanks missing, you can see the bus bar when you lift the cover :grimacing:.
I may or may not be able to get some blanks and refit the cover correctly to tidy it up but, I think I am going to advise the landlord to upgrade to a AM3 compliant non-combustible board as it seems nuts to me that this is on the only escape route from the top floor and it is not in any type of non-combustible enclosure.
Any thoughts or advice would be appreciated. i.e. Would you agree the upgrade should be done? This is a new customer and second job and I don't want him thinking I am creating work but I feel it is unsafe as is. Also I will be modifying circuits which come from this board.
It does not need to be replaced for a metal one to be made safe.
To be made safe the exposed live parts should have been dealt with immediately. What action did you take ?
May want to check with LBC as their HMO building regs may require a CU in a fire escape to be fire rated. And adding circuits may trigger that. Worth a check?
Hi - having cup-o-tea and looked at website of LBC I use (Reading). I think they require a fire rated CU.
From page 4 : "Any electric or gas meters in the (escape) route must be enclosed in half-hour fire resisting construction. "
http://www.reading.gov.uk/media/139...rds-In-Mandatory-Licensable-HMOs-May-2008.pdf
That is for licenced HMOs. Not all HMOs are licenced. I believe the guidance and requirements for licenced HMOs are usually stipulated by individual councils.
The passage you refer to mentions meters, not distribution boards. In this case the distribution board is not the main one so not likely to be near the meter. The passage mentions half hour fire resisting construction, not non combustible. Plasterboard, as an example, will offer 30 minute protection.
I would argue even fitting blanks is still dangerous as you do not need a tool or key to open cover or remove blanks so not safe. So...advise client new CU should be considered to make safe.
Reply to Consumer Unit on Stairwell in HMO in the UK Electrical Forum area at ElectriciansForums.net
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
Hi All, I am in the middle of purchasing a small 1 bed flat in England, and have been sent a Domestic Electrical Installation Certificate by the...
Hi all, new to posting but been reading for years. I inherited a house from my grandmother who passed in 2021, I intend to renovate and rent out...
10K
Hi guys. Just need pulling into check on this one. I’ve been asked to wire an extension including new lights and sockets and SD’s ran from...
Hi, I am looking to get an electrician to upgrade my consumer unit and do some work on circuits. At the same time, have been receiving letters...
8K
