Looking to upgrade the current consumer unit, it is located in the garage, the new cu will be in the same location. Having read various posts it appears that the Hager boards are well regarded but the MK boards not so
But my electrician is adamant in wanting to install an MK RCD board 13 way, he advised 13 way is a bit more than my actual requirements but it will be future proof in the event i decide to do an extension or something
I suggested a Hagar board but he dismissed that! And insisted to fit an MK board as he is familiar with them
Your thoughts would be appreciated, where does the MK board rank? Would you recommend any other CU other than Hagar?
Why does "your
Why does your "Electrician" demand that you have to change your CU? has he done any testing of the installation? probably has the one he is recommending kicking around in his Van, get a second opinion.
Pic of current consumer unit attached, there is one for immersion heater and electric shower but these are no longer needed for the new CU. This one is Hagar :)
May also do a garage conversion and also fit mains smoke alarms, and in the future but unlikely may do a rear extension, rather be safe than sorry
Install is for normal rcd board not rcbo
Could you provide links to what Hagar board i should buy please i.e 10, 12, 14 way if there is not much price difference then happy go with 14 way
If your electrician has said get a 13 way then I would get a 13 way. Usually during the pre-works visit I would open up the CU, he may have done this and seen lots of extra conductors in each circuit breaker and realised that you need (for example) 10 used ways, therefore you will have 3 spare.
It really doesn't matter if you get hagar, wylex, crabtree, MK, BG etc etc etc. They will all be exactly the same for you (barring cost), it's just about personal preference for the installer. He probably has plenty of MK spares should anything go wrong and he needs them.
Existing 7 circuits + Garage +smokes+ extension + any possible existing doubled up circuits
Seems to be a reasonable suggestion by your own spark
Best go with the advice given by your electrician on the job,he is in a far better position to make recommendation than anyone from afar
He's told me to supply the board but not sure what to go for any links to the product to purchase will be appreciated there are so many different ones to choose from:oops:
The price for a distribution board can vary enormously
You have to take into account what you are prepared to pay because it has a great influence on the type of board to fit
If price is no problem,then a full RCBO board is a must,if cash is tighter then the regs permit systems that comply but may not give the same ability to cause minimum disruption in the event of a fault
You may be advised to be open about what you can afford
Are you cash tight or is pounds no problem? :)
I have a budget as renovating complete house, so do not mind not having and rcbo board but happy to pay for the best rcd board that is currently out there :)
Uk
Consumer unit upgrade
ash121,
JOURNEYMAN,
