Discuss Control Panel Building. in the Canada area at ElectriciansForums.net
Jason.s have you got any detail as to what is required and ideals on how you want to go about it. i can also do drawings on a wiring package if it helps. :)
PS no cost incured
Hi Andy,
Thanks very much for the kind offer!
I may well take you up on that.
I have yet to go and see the job as it is some way away from me.
Hopefully going to get up there in a couple of weeks to get an idea.
Not entirely sure on finer details but it may involve a variable speed pump and drive along with tank float switch, rain switch, programmer etc.
Cheers
J
Jason, you don't say where your based.
It sounds interesting. Do you have a rough idea as to the size and number of pumps, control valves etc.
From past experience you may have to add a fair bit to the design, I’ve lost count of the number of times I’ve had to have valves added to a system to cope with silly things like priming
Re: Control Panel Build.
Hi Jason, I would also consider helping, as long as there is an abandoned barn!! with some Oxy-acetylene a grinder and some welding gear and a shed load of duct tape!! But seriously if you need anything and we can help we will.
What in the name of god are you waffling on about!
Reply to Control Panel Building. in the Canada area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi all, Some background on this question: I am UK-based, and I work with robotics and automation, so have experience with PLC programming, robot...
Hi all, my name is Darren and i am the owner of control 101. we build small to medium control panels and are always looking for new customers, so...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
We have just completed a self build, and heating system is Air Source Heat Pump, unvented HW cylinder, Buffet Tank, all Vaillant equipment. The...
