Discuss Couple of question about Can-bus ready LED's in the Auto Electrician Forum area at ElectriciansForums.net
Hello at present I drive a Vauxhall Vectra C 1.9cdti 16V 150bhp 56 plate.
I wish to add some extra lights to my vehicle, as in Angel Eyes (Halo rings) to my head lights, also some extra indicators to the door mirrors and possibly some LED strip lights to the headlights that also connect to the indicators.
My question is does anybody know if the factory fitted fuses can cope with the extra drain or do I need to add something or upgrade the fuses.
Sorry if it sounds strange or confusing.
Many Thanks in advance.
The fuses are there to protect your wiring from being overloaded so don't change them for higher rated ones. It could catch fire.....saying that, if it's a Vectra....it might be doing you a favour :). My main concern here is that the lights may be worth more than the car is....
If you do wish to do it then confirm your existing circuit loads, ideally a clamp meter or otherwise by calculating your existing loads in watts and converting to amps. Then you can work out what spare capacity you have. You may also need to consider your existing relays and if they can switch the additional load.
Reply to Couple of question about Can-bus ready LED's in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
I have the typical LED on Dimmer switch. All the lights flicker in my house are very inconsistent times. By let me clarify by saying all the...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
