Discuss cpc in switch boxes in the Australia area at ElectriciansForums.net
Some surface boxes have an earth terminal specifically for that.
If they dont then i just crimp them through, unless a metal plate is used...
But that would look naff on a pvc box.
I sleeve it with the sleeving a bit longer than the conductor and fold the end over gently. This may be against a reg but it was a habit I got into and have never found out whether it's kosher. I'd be happy for confirmation one way or the other.
If there is't a termination in the pattress for the cpc then i just earth sleave it and connection block, then it's there waiting for anyone else who may need it in the future. don't really see what else you can do
Reply to cpc in switch boxes in the Australia area at ElectriciansForums.net
Not the usual per-1966 sort of "no CPC in wiring issue" but plastic light switches in plastic back-boxes in trunking wired in singles. The lights...
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
