Discuss cu change in bungalow in the Australia area at ElectriciansForums.net
flukey
just been to see a cu change in a tiny bungalow.
only 4 circuits in existing cu. question is what board can i get away with fitting as they obviously dont want a dual rcd board. all advice welcome ;)
Its either that or a dual RCD CU.
Contactum is pretty good and fairly reasonably priced.
hi jason, ive got 3 brand new wylex 10 way dual rcd boards that i aquired at a very reasonable price but i didnt really want to waste one on a job like this, looks like i am gonna have to though :mad:
You gotta use 'em somewhere!!:D
However, i do see what you are saying.
I'd be thinking the same as you.
seems a false economy wasting a nice board like this on such a small place :mad: still if they decide to extend to the side, put a second story on, add a garage and garden shed along with a new shower and security lighting, the stannah stairlift and hoist at least they will have enough room on the board ;)
You are all heart:D
How much were the Wylex 10 way dual boards?
Cost of the 6way contactum cu + 4x rcbo's & 2x blanks £67.00 (thats with my discount from wholesaler)
Cost of a Wylex dual rcd 10 way cu + 4x mcb's & 6x blanks £50ish (again with discount)
Use your Wylex & you'll be loosing money as this job wont cover the potential income if the Wylex was used on a 2 storey property with more circuits.
Is your glass half full or half empty?
you must get a good discount then as i couldnt just about buy the rcbos for 67 quid, who is your wholesaler and what do you pay per rcbo?? :confused:
same with the wylex, 60 quid + vat at my wholesale + mcbs on top :mad:
looks like i could be changing wholesalers ;)
Hi flukey
well i was abit weary at the beggining but i tell u what they are preety good, ive had quite a few problems with mk breakers lately! But to be honest i havnt installed loads but what i have done are ok. O ye its plus vat too, not bad if ur on a budget.
Cheers
Hi flukey
Cheers
still cant see how notclever can buy a cu and rcbos for 67 quid as these rcbos add up to 58 quid on there own and ive never even heard of them :confused::eek:
screwfix do wylex 10 way, split CUs, dual RCD with all the mcbs for just under £100. You can then keep 6 of the mcbs for the next job!
Reply to cu change in bungalow in the Australia area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Morning guys, Just been to look at a CU change and there was a bit of an oddity with the PME connection in the old black cut out. Looking at the...
