Not if the job is done properly, fires in cu's are caused by nupties not doing the terminals up
Might get you out of a hole if you had a really awkward one. Are the terminals round to go with the round tails though??
Yes the terminal are round, these are much easier to use than trying to bend 25mm or 35mm tails which then end up pushing your main switch out of line. I have been using them for the last 5 years and never had a problem.
If im not mistaken electrifix have some dimensions in the catalogue, might be worth a look.
Had a similar problem once With the meter tail issue. Tried to use the the meter tail kit like suggested but I didn't trust it at all. Joint wasn't secure and it kept becoming loose etc. In the end decided to replace the tails. The currents ones turned out to be sunken in to plaster anyway and a drill bit had already nicked the live. This was upon further inspection. Absolute nightmare to replace as there was a damp proof tray in the cavity. Thankfully it wasn't my own job and I was only subbing.
Doepke do one with left hand side main switch. Height dimension is 204mm. I've just bought one with breakers for £112.
Many thanks! Just the job! A good make too. Though I have an account with Bew I got a better deal from CEF, only by about £20 though.
Cheers!
Pete
Or install a rec2 isolator before the CU (assuming you have room) then "extending the tails" is easy....although they are plastic :stuart:
Hi Guys
I'm wanting to replace an old 8 way consumer unit which is above the kitchen cupboards. I've limited height of 233mm. All cables are top entry but the tails are to the left of the rest and no doubt won't move.
Anyone know of a Amd3, dual RCD unit , min 8 ways, max 230 mm height, left hand mainswitch which will fit the bill, please?
I'm aware I could possibly put it inside the cupboard connected via a large terminal box, but I'm not keen!
Just saw this post. MCG make a board which is 235mm (so depends how critical that 5mm is for you).
