Discuss Current electrical regulations help please. in the UK Electrical Forum area at ElectriciansForums.net
Looking for advice.
Can you advise the current situation with having minor work carried out., as to regard of certification.,
1. Installation of new shaver point in bathroom. no previous point in bathroom.
2. installation of spot lights in bathroom ceiling to replace pull cord. ( switch on outside bedroom door.)
3. Reposition of shaver point from one wall to another. different bathroom.
4. New electrical shower pump installed.
looking up on line and its very confusing !
Thanks for your help.
Henry
The work sounds like it could be covered by BS7671 Minor Electrical Installation Works Certificate(s) but that doesn’t affect a possible requirement to notify Council of the work under Part P in England and Wales.
The bathroom is a Special Location and Part P of the Building Regulations wording is something like “alterations and additions in a Special Location are to be notified”. But there are zones defined so that if your bathroom was open plan (!!!) you wouldn’t need to consider the whole house a Special Location, at least under the wiring rules.
Just looking for what we need to do to comply with the regs., and what or who issues the
certification, or if that is needed..
the lights and shaver points are in zone 2 if thats helps.
1. If a new circuit then EIC or if taken from existing circuit then MWC.
2. If an alteration to an existing circuit then MWC.
3. If a new circuit then EIC or if taken from existing circuit then MWC.
4. If a new circuit then EIC or if taken from existing circuit then MWC.
My certificate software has minor works cert that covers up to 5 alterations so if no new circuits are installed you could use one of them but as others have said it sounds like the work is notifiable
Reply to Current electrical regulations help please. in the UK Electrical Forum area at ElectriciansForums.net
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
Hi I am seeking help and best practices to achieve below tasks. I am not across regulations hence will appreciate best approach to achieve below...
