Discuss Cut wire to lamp, nothing else working in the DIY Electrical Advice area at ElectriciansForums.net
unlebob
Hello, I have an outside light attached to a lampost. The head which is badly damaged and needed replacing anyway has blown off in the wind. To prevent further damage I switched off the electricity and cut the wire (thick flat wire with 3 smaller wires) intending to temporarily terminate it. However when I switched the electricity back on other lights and an electric gate on the same breaker are not working.
Any idea why not ?
The breaker does not "go" once turned back on.
Has it tripped an RCD somewhere maybe?
When you cut the wire to the faulty lamp, did you make sure none of the cores were touching?
Reply to Cut wire to lamp, nothing else working in the DIY Electrical Advice area at ElectriciansForums.net
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
