Discuss DALI compatible LED driver and LED strip. in the UK Electrical Forum area at ElectriciansForums.net
Sid
Good evening all,
I have a job to do fitting multiple sections of dimmable LED strip to be controlled by a DALI lighting system.
Can anyone recommend LED drivers and strip that are DALI compatible?
I would be grateful for any guidance/assistance.
Thank you
I would say number one make sure the control gear and LED lighting/strips are compatible with each other and DALI systems prior to purchase. I cannot stress this enough! I have had massive problems with DALI getting any endorsement for any control gear or LED lighting before. Can I ask what kind of system you are adding LED to? Usually DALI systems are large and expensive control systems used in large places is that the case here?
An example of a dali driver for 24V .
Have found Tridonic nearly always have a solution. Have not personally used this driver as all the ones i have used so far have been constant current.
So, choose 24V strip, choose the wattage for driver, dim away......
BTW , these are single colour.
For RGBW i used a tridonic CV driver through a KNX 4 chn controller.
P&S
Thanks guys.
Yes, I believe
Yes, I believe it is going into an existing DALI system in a hotel. 30 mirrors each with 2 x 2m warm white dimmable led strip to the vertical edges of the mirrors.
We are fitting the strip and drivers off site with plug and play mains lead for on site electricians to connect
[automerge]1595222183[/automerge]
P&S
Thank you.
Can you recommend a manufacturer for the led strip. Dimmable warm white
Reply to DALI compatible LED driver and LED strip. in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
