Have a look at OSG (Blue copy) Appendix L Page 207 this may help.Hi
Can someone point me to the description of IPXXB and IP2X in BS 7671. I know what they are and the requirements of each of them are, but I cannot locate the description in the Big Blue Book.
Appendix 5 on page 450 has the details of IP 0, 3, 4, 5 & 6X but not the other 2.
Cheers
Try "Degree of Protection" 705. something" in the BYB don't have the 18th shouldn't be hard to find under degree of protection.Hi,
They are in the On Site Guide, and probably in Guidance Note 3 as well. Im more interested in knowing if they are in BS 7671 though, for the 18th edition exam I think you are only allowed to take in the big book, so I trying to find out where this information would be found?
Hi - as per Pete in the Index under "degree of protection" and there's lots of references listed. The one you've asked for is 416.2.1 - I'm doing the test next week tooCan someone point me to the description of IPXXB and IP2X in BS 7671.
Are you doing the course or just the exam?416.2.1 doesn't tell you what the requirements of IPXXB & 2x are though, unlike in the on site guide where it describes the requirements of the codes. I want to know where in the BBB it states the requirements of it, it tells you what the other IP ratings for foreign bodies are in appendix 5 but it doesn't mention these.
I've not seen the IP definitions listed in BBB either. They will be detailed in their own standard (BS60529), I think.416.2.1 doesn't tell you what the requirements of IPXXB & 2x are though, unlike in the on site guide where it describes the requirements of the codes. I want to know where in the BBB it states the requirements of it, it tells you what the other IP ratings for foreign bodies are in appendix 5 but it doesn't mention these.
IPXXB Access of a finger is not possible 207 OSGHi
Cheers
to the back of the skull.IPXXB Access of a finger is not possible
a sausage to big to go trough little hole in the c/u.IP 2X Penetration by a solid object
