Discuss Difficult customers - and remedial works in the UK Electrical Forum area at ElectriciansForums.net
K
Ken77
How does everyone deal with difficult clients?
Today I have had a client kick off claiming we have scratched their floor. The flooring is lino so is prone to scratching. We have been putting spot lights and despite dust bowls and dust sheets some dust has got onto the floor and this has shown up every scuff mark on the floor.
We didn't take photo evidence of the floor prior to the work and nor did the client. We have had to move furniture so it is possible we may have caused some minor scuff marks, but I am sure these would go once the floor is cleaned properly. By minor I mean hairline scratch.
Client has asked us to leave the property before we had a chance to clear up properly so there is plasterboard dust on the floor and makes us look like right cowboys leaving a site in a mess.
I apprecriate that from the clients perspective it may look like light we have scratch the floor, but the is no certainity it was us. There was no evidence of scratches before the work commenced, but as I say these may have only become appararent due to the dust.
As the client hasn't let us clean up (despite us requesting to do so), we can't see what state the floor is in post work, so we can't compare it to how we found it.
We are likely to end in dispute over this.
In the same week - we have had a call out regarding an apparently faulty sensor light we installed that we have already replaced once.
On initial installation we used the existing wiring (which we tested and seemed fine). 1st senor lights (Microwave sensor) was replaced as client complained it was not operating as it should. 2nd sensor light was installed with PIR - after a short period we had a compliant it was flickering on/off rapidly or not coming on at all).
I replaced the sensor for free (material and labour) on the first occasion, but for this 2nd call out I feel it maybe necessary to carry out further investigation given that 2 lights have failed so quickly, and that this should be chargeable. The client feels we as though this should all be covered by us - and mere suggestion of an additional charge is outrageous.
What do other people do in these situations? Do other electricians walk around a house and make a note of every mark or blemish on the property prior to commencing work so this can be cross referenced at the end of the project?
Would you consider it reasonsible to charge for investigating the wiring further after 2 sensors have failed previously and you know it it not down to your workmanship! If it turns out that is was bad luck we had two shoddy sensors who should pay for our time for refitting faulty parts?
Your first scenario sounds like a straight forward insurance claim to me. The customer fills in a claim form, you furnish them with your side of the story and the client get paid out whatever is negotiated. This shouldn't prevent you from finishing the work or completing the clean up or getting paid for that matter either.
Second scenario is different, it swings around warranty claims. Personally I'd find the problem and fix it at my expense even if it is on the existing circuit. You should be able to get the faulty sensor lights refunded by your wholesaler and the labour would be for your account I'm afraid. Bottom line is you should be charging sufficient mark-up to cover warranty claims, you might come short on one job but more holistically in the long run with many jobs you should be in profit.
You sound like you have been fairly decent about it all to me. Think Marvo sums it up nicely, though if ultimately you do have to replace the vinyl and if the room is smallish I would just pay it myself rather than through insurance probably.
The second aspect is a little trickier possibly. I would probably replace the sensor again and if it fails quickly again put in writing that the circuit needs looking at in more detail and at greater expense. If the test results at the time of the initial install were fine then can't really fault you. I would try a different brand of sensor if possible.
With some clients you have to bit your lip sometimes mate, it's just part and parcel of it all.
Not sure about the units that are sold in the UK but the sensor lights and PIR's around here are notoriously unreliable.
I find they can be! Had several dodgy ones from reputable brands in the past.
Sounds to me like your first scenario, is the customer engineering an insurance claim. Submit your bill, and see how they reply back. Offer to have the cheapo bit of lino professionally cleaned. If they decline, depending on you insurance excess, I'd then put in the hands of you insurance company and let the assessor at them. If a piece of lino is the cheaper option, as suggested , you might have to concede.
This job would be alright if it wasn't for the customers!
Nowt as queer as customers, this is a bit off topic but at the other end of the scale I had a snag this weekend, I've been working away at an exhibition so bad to call a mate in to cover me, the customer then turns around and asked me to send her the bill to cover my mate, and it was my fault not hers! This is rare.
A lot of the old time customers were like that up here . The money was on the mantle piece before the job was even started, and a place laid at the table at lunch time .
There are some left , but few and far between.
Reply to Difficult customers - and remedial works in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
Hello there my fellow electrician. Need some advice about a customer who is being very difficult and annoying. I was called out by the customer...
4K
Hi all, Just wondering what the general situation is with other people on smaller jobs, do you give a quote or estimate to the client before you...
