Discuss Dimmer switches and LED Bulbs in the UK Electrical Forum area at ElectriciansForums.net
Hey folks,
I just wanted to check something. I have 3 x 4W LED light bulbs on a 400W dimmer switch. I’ve read all this stuff about making sure the dimmer Wattage is right for the LED bulbs but it doesn’t say anything about the dimmer Watts being to high? Would this affect the Bulbs?
They worked fine for a few days, but now I've noticed that the bulbs max brightness has decreased?
Any advise would be greatly anticipated
Is the 400W maximum for LED load? Many dimmers will reference the incandescent load it can handle. This in retrospect will lead to a lower maximum load for LED's and that's only if the dimmer is suitable to work with LED's. Do you know the make and the model of the dimmer?
Thanks for the response gents,
The max and min load for the dimmer is 50W - 5W for LED which I’m well within at only 12W.
The dimmer is a British General 1-Gang 2-Way 400W push dimmer switch from Screwfix.
I’m starting to wonder weather it’s a fault with the LED bulbs themselves.
Reply to Dimmer switches and LED Bulbs in the UK Electrical Forum area at ElectriciansForums.net
The G4 110V 3W dimmable bulbs I purchased work with a dimmer. I can brighten them and dim them, but when I turn the dimmer off, the LED bulbs...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Sure this has been answered before, can’t find a specific answer though. My house was rewired in 2021 and as part of the rewire I had LED lights...
Hi, I currently have 4 JCC LED down lights in my bathroom with a 2 gang dimmer on the outside. The first dimmer switch controls the LEDs and...
I've read lots of conflicting information on the internet about dimmable LED lightbulbs. Some people have said that even if a supplier claims that...
