- Reaction score
- 739
I need to install 2x 600x1200 led grid fittings into a small office.
The occupant needs to have the option of dimming the light levels because of the nature of her work.
IV found a couple of fittings but not sure how I source the correct dimming option. Domestically, anything I have installed with a dimming function has just relied on the switch itself dimming the fitting. All the fittings iv found so far have DALI, 1-10v, switch dim, push button dim.
My question is, do you have to have these systems in place to use one of the options above? We use DALI here so I know that system has to be installed but unsure of the others.
